Low mass boiler for commercial building
JC from PA
Member Posts: 16
Has anyone used,or recomend a manufacturer of a good low mass boiler for a large commercial application? Space is an issue, and I thought maybe a low mass would take up less room and also elimanate standby losses. I am also looking for information that would give me energy and maintenance costs for steam vs. hot water systems in a large commercial setting.
Thanks!!!
Thanks!!!
At what effiency level ?
Lots of choices out there, dependent upon load and efficiency desired who to look at.0 -
Laars
makes some of the largest condensing boilers I've seen. Rheos goes up to 2.5 million BTU's0 -
Efficiency level
Efficiency level
I'm looking at everything available in low mass right now.0 -
Viessmann Vertomat available from 300 mbh to 3,361 mbh inputs. 2-stage and fully modulating burners available. INOX HX so it's sort of like a Vitodens on steroids. Wicked high efficiency. Presume the price is wicked high as well
