Boiler Installation
Installed 2 gas boilers. Hade old hot air units.
Anthony
  • Anthony Mobilio_3
    Anthony Mobilio_3 Member Posts: 62
    Boiler Installation
    Installed 2 gas boilers. Had old hot air units.
    Anthony
  • Larry_10
    Larry_10 Member Posts: 127
    looks like a real nice clean install good job
  • lchmb
    lchmb Member Posts: 2,997
    very neat
    Very nice job. Couple question's for you though, what kind of control package are you running this with? That and do you service your install's yourself? Curious because I like to see a few more shutoff's myself...That way at two a.m. I don't have to drain the boiler to replace the expansion tank of the circulator. Or for that fact the fast fill.......Keep up the nice work
    P.S. I'll let someone else pick on you about pumping away! :)
  • Weezbo
    Weezbo Member Posts: 6,231
    i like the simplicty,and straightness and hammond valves*
  • Larry_10
    how dose one know if the expansion tank is bad
  • ed wallace
    ed wallace Member Posts: 1,612
    boiler install
    very nice work but you should have put the circulaters on isolation valves and is that teflon tape on the gas lines ?
  • Isolation valves
    I agree with you, isolation valves are a good idea for easy maint. Once suggestion though, if I put an isolation valve on something like the expansion tank, I always take the handle off the valve put the nut back on and hang the handle nearby...
  • Anthony Mobilio_3
    no teflon tape we used pro dope the white is the wire ties We sevice everthing we install oil, gas, heatpump and electric furnaces aslo 98% of the time we do install them pumping away.
  • kevin_22
    kevin_22 Member Posts: 4
    install pics
    Pics. look like a nice neat job. But I woud have had the circ. pump on supply with expansion tank on low pres. side of circ. and water feed on high pres. side and as others have mentioned valve on exp. tank and iso flanges or more valves on each side of circ. I also do not see a LWCO but am assuming all radiation is above the boiler.
  • bob_44
    bob_44 Member Posts: 112
    Angel
    Tony, you are destined to be an angle. As my daddy always said you gotta be plumb, level and square to get to pipe heaven. Good work. bob
  • Anthony Mobilio_3
    Thanks, the LWCO in a mini 1100 safe gard type. its on the supply...
    Anthony
  • Nice work Anthony
    Everything level and square , and easy to service . I , like you , take the minimalist approach in regards to isloation valves . A separate valve above each pump , and on each return , and you can isolate whatever you need with minimal hassles . Although I do like the idea of having valves on each side of the pump , I don't think them necessary on a part that will probably never be changed in the life of the boiler .
