Recommendation for thermostatic mixing valve w/outdoor sensor
Steve Garson
Member Posts: 191
Can anyone suggest a mixing valve that will use an outdoor sensor to adjust the temperature output of the valve. My radiant loop needs 145 degree water when the outdoor temp is 0-degrees, and 120 degree water when it is 30, etc. Right now I manually adjust the water temp, but the system should have been installed to do this automatically. The zone is 3/4-inch.
To add insult to injury, when they installed the tubing, they didn't do the right calculations, so the solution was to increase the pump head, so I live with velocity noise from the wall where the pipe rises from the basement.
Thanks
Steve in Boston
Thanks
Steve in Boston
Taco
see www.exqheat.com for a reset control which will work off your current thermostat.0 -
Taco
Taco has an "I" valve that is exactly what you are looking for. Check with your local supply house..Good luck.0 -
Stadler -Viega
I've used a few of these
http://www.stadlerviega.com/productDetails.asp?prodID=147&prodCatID=11&areaId=2
I think this link should work0 -
mixing valve
> I've used a few of
> these
> I
taco I series
Like some others have recommended, check out the Taco I series mixing valves. They provide outdoor reset, boiler protection, ant high limit for floor protection as well. Simple, effictive, and cost efficient.
Marco0 -
Definitly Taco makes a good product. You may also want to look into some form of boiler reset control tha Tekmar makes.
PATRIOT HEATING & COOLING, INC.
