Panting and gurgling - spreading to all radiators (steam)
Dave_55
Member Posts: 4
This is a 1920s residential steam system converted to gas in 1948, one-pipe, two branches. We solved a problem with uneven heating after installing efficient windows by lowering pressure to 1/2 in, 2 out, and changing out all the valves. At first one radiator was making a bad rushing noise, and panting; now all upstairs radiators are panting, two are gurgling/rushing very badly, and one downstairs radiator is panting. In addition, for two years, downstairs radiators have been filling the valves with water. We were unaware of Dan's work and this site until recently. We have not cleaned the system in the 7 years we've been here so it could be clogged returns. We would like to know (a) if that's the problem, and (b) who can visit Teaneck, NJ to fix it. Thanks...
Could be that or some other things
Try Ken Secor of Palmer Heating, in Rahway. You can find his contact info by following the instructions on the Find a Professional page of this site.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"Baltimore, MD, USA
Consulting0 -
Thanks. Would still appreciate your thoughts on what the problem might be. If it's something else that I can handle myself...0
- 120 Geothermal
- 169 Indoor-Air Quality
- 396 Solar
