Steam returns
TGO_54
TGO_54 Member Posts: 327
Have a job where the buried dry returns on one side of the building are leaking. The dry return for the other side of the building is large enough to handle the entire load so I am going to connect them and abandon the leaking return. There is one condensate drip where the main goes up over a doorway and back down on the other side. Is there any reason I can't re-route the drip using a loop seal and tie it back into the dry return?
Thanks
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=278&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
