Pressuretrol on a hot water system?
Inspected a house yesterday with an old forced hot water boiler. Gas fired, 2 zone, in a 57 year old cape. While checking the piping and controls I look up to see a pressuretrol mounted on the piping... Was this ever a common practice or is there any situation where this could be appropriate? Everything worked OK. It reached temperature and shut down the burner, circ pump kept running till heat call was satisfied... Maybe some deadman's juryrigged inovative pressure safety? Thanks in advance for your help...
