hot rodding the Grundfos Super Brute
hr
hr Member Posts: 6,106
about jazzing up this wonderful circ pump.
For under 2 bucks you can get these green lights from Radio Shack. A 9/32" drill bit (I wobble my 1/4" bit:)easily drills the plastic case in any one of several locations.
Slip in the bulb and wire to the quick connectors.
Let's face it, circ stick mainly due to the water of fluid conditions they are exposed to. Know that not every system will see optium fluid conditions, Grundfos engineers have added this tickler that vibrates and helps dislodge a potentially stuck pump. Much better than turning them into a toaster :)
I'm still trying to find a good way to add pressure test ports on both ends of the volute. Not much meat for drilling and tapping, anymore :) I need a 1/16" pipe nipple and tap!
hot rod
<A HREF="http://www.heatinghelp.com/getListed.cfm?id=144&Step=30">To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"</A>
  • Mellow_2
    Mellow_2 Member Posts: 204
    hot rod
    I have seen large circ flanges with test ports in them do they make small circ flanges with the same thing? I wonder......
  • S Davis
    S Davis Member Posts: 491
    Pressure ports
    I tried to find some recently and did not have any luck, if any of you guys find some please let me know.
    S Davis
    Apex Radiant Heating
  • hr
    Sounds like a good project for
    the Webstone iso flange people :)
    I've been using a lot of these Watts purge valves lately. Find them inntheir hydronics catalog. Solder a couple to your favorite sweat flange any away you go. They already have a 1/4" threaded port for a gauge connection!
    Now you have iso and test ports. Even a purge port if you get clever :)
    hot rod
  • Not available yet,,,
    The new 15-58's are going to replace the old style & the only ones I've been able to get was from the ISH.-NA. Special order for me and 6-8 weeks out.
    I sure wish they would tell us this before demonstrating in the glossy's of PM & Contractor.
    The old style is the same as the new with small improvments. Now a BX connector fits onto the box and the thing also looks much cooler! Grundfos is allways improving and that's why it's my pump of choice.
  • kevin coppinger_4
    kevin coppinger_4 Member Posts: 2,124
    I have used the ...
    new ones and I actually like the older set up better. the cover is more friendly...The rep told me they heard that the old style got complaints about the switch...some people had a hard time figuring out the way to switch speed...(I suppose the screwdriver was not handy???) I actually thought that it stopped the HO from messing around with things thaey should not be messing around with. I guess I will live with it. kpc
