Replacement Air Vents
Bob_43
Member Posts: 16
I need to replace the air vents in my house, does anyone have any opinion between the Hoffman 1a, Dole 1a, or Heat-Timer VariValve valves. Thanks.
Gorton, Hoffman, Dole and Vent-Rite
are all good. Gorton's vents all have fixed ports, but the other three make adjustable vents as you know.
I'm not so fond of the Vari-Valve, it's too easy to open this vent too far, making the radiator spit water.
How about the vents on the ends of your steam mains?
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0 -
I was going to replace the vents on the steam mains with Hoffman 4a vents. I think the main vents are the root of my problem, but since all the vents are old, I thought I would relace them all since I am not happy with the way the system is heating.0 -
Sizing Main Vents
I think I said this in your other post, if you're the same one who asked about those 4A vents. But if not- measure the length and diameter of your steam mains, and we can tell if the 4A is the right vent or if you need something else.
Consulting0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
