Pipe Insulation Question
well i would say everything, however im no expert, but i would say by doing all of it , that would use less energy heating up water thats allready hot..
  • Vito Cavallo
    Vito Cavallo Member Posts: 23
    Pipe Insulation question
    My old one pipe steam system is uninsulated. Must have been asbestos once and then removed. Do I only insulate the risers and the main feeds?
    Should I also insulate the wet returns and the Hartford loop and any pipes below the water line?
    Thank you.
  • tom_54
    tom_54 Member Posts: 46
    at the very least
    insulate up to the main vents...that is the most important. You do not want the steam condensing before it has had a chance to get to the rads.
