Pipe Insulation Question
NHPluminator
Member Posts: 17
well i would say everything, however im no expert, but i would say by doing all of it , that would use less energy heating up water thats allready hot..
Pipe Insulation question
My old one pipe steam system is uninsulated. Must have been asbestos once and then removed. Do I only insulate the risers and the main feeds?
Should I also insulate the wet returns and the Hartford loop and any pipes below the water line?
Thank you.0 -
at the very least
insulate up to the main vents...that is the most important. You do not want the steam condensing before it has had a chance to get to the rads.0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
