control wiring
Andre
Member Posts: 11
When converting a boiler from a tankless water coil to a indirect water heater, is there any modification needed to be made to a L8124A relay before adding a three zone SR503 switching relay. Not using a cold start
Could someone give a clear explination how the high and low limit settings work? Exactly when each one does its function and whats going on to activate them.
Andre
Andre
Use the cold start boiler diagram
No, just use the low voltage TT terminals on the aquastat to energize the boiler, as opposed to the ZC, ZR terminals.
Taco, Inc.
Joe Mattiello
Technical Service Technician
joemat@taco-hvac.com
401-942-8000 X 484
www.taco-hvac.comJoe Mattiello
Taco Comfort Solutions0
- 120 Geothermal
