control wiring
Andre
Andre Member Posts: 11
When converting a boiler from a tankless water coil to a indirect water heater, is there any modification needed to be made to a L8124A relay before adding a three zone SR503 switching relay. Not using a cold start
Could someone give a clear explination how the high and low limit settings work? Exactly when each one does its function and whats going on to activate them.
Andre
  • Joe Mattiello
    Joe Mattiello Member Posts: 748
    Use the cold start boiler diagram
    No, just use the low voltage TT terminals on the aquastat to energize the boiler, as opposed to the ZC, ZR terminals.
    Taco, Inc.
    Joe Mattiello
    Technical Service Technician
    joemat@taco-hvac.com
    401-942-8000 X 484
    www.taco-hvac.com
    Joe Mattiello
    Taco Comfort Solutions
