Bronze valves and cast iron radiator, electrolysis a concern?
Weezbo
Member Posts: 6,231
izzzz good for the go.
I need to re-connect an old cast iron radiator.
I found the valve and fittings I need. The easy to find valves all seem to be bronze/brass.
Is there anything to think about here with respect to electrolysis?
...Tom M0 -
You will not have....
Any problem at all! Be careful with the brass fittings...they can break easily.
Thanks for the info
Thanks for the reassurance, guys!
...Tom M0
- 120 Geothermal
