Bronze valves and cast iron radiator, electrolysis a concern?
Weezbo
Weezbo Member Posts: 6,231
izzzz good for the go.
  • Tom Morgan
    Tom Morgan Member Posts: 2
    I need to re-connect an old cast iron radiator.
    I found the valve and fittings I need. The easy to find valves all seem to be bronze/brass.
    Is there anything to think about here with respect to electrolysis?
    ...Tom M
  • jeff_34
    jeff_34 Member Posts: 5
    You will not have....
    Any problem at all! Be careful with the brass fittings...they can break easily.
  • Tom Morgan
    Thanks for the info
    Thanks for the reassurance, guys!
    ...Tom M
