thermostat
MattV
Member Posts: 27
I have a honeywell ct3600. Smart response or conventional heating whats better for a one pipe steam system or does it matter.
On a conventional system without outdoor reset, then it's really your preference. I assume you want to use setbacks or you wouldn't be asking the question.
If you're in a fairly constant climate and your system response is predictable over the year, then normal timer mode would work fine.
If your climate varies and you want the thermostat to compensate for longer/shorter seasonal recovery times, then using Smart Response is a good idea.0 -
Thank you
Thank you0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 2K Domestic Hot Water
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 945 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
