How do you temporarily remove a two pipe radiator on a operating
D. Ryhter
Member Posts: 1
I need to repair the plaster behind a two pipe radiator.
The system is operating at about 3 lbs.
Can I shut off the radiator at the valve and remove it? DO I need to cap the return line or just duct tape it closed.
When I re-install the radiator do Ineed to do anything to the boiler or system.
THANKS
D.RYHTER
HAPPY HOLIDAYS TO ALL.
THANKS
D.RYHTER
Rad removal
I've removed the valve, rad, and trap and temporarily capped the pipes. Lets you do the job right. Then just reinstall. Don't use thread dope with oil, just teflon tape. The oil will find its way back to the boiler and make trouble.0
