Thermidistat question
Ed_23
Member Posts: 6
I'm looking for a digital humidistat and have only come across the Carrier Thermidistat. Can anyone tell me if I can use this to controll an Aprilaire 360 and also replace the 2 wire thermostat for radiant heat? Does anyone know of a digital humidistat only? Is there any thing else besides the Carrier that will work? Thanks for any advice. -Ed
EWC
Ed,
EWC (AutoFlo) makes a digital humidistat. It also comes standard with their new steam humidifiers. -DF
It
requires a common but otherwise would work on 2 wire heating only. It puts out 24v when calling for humidity. Not sure what the 360 requires. May need a simple relay to trigger the Aprilaire. White-Rodgers makes the 1F95-391 which will do the same thing as the Thermidistat. Similar high buck price tag.0 -
John, the Aprilaire 360 has a built in relay, the humidistat that came with the unit just has a two wire connection that triggers the relay. If the Carrier and White Rogers models put out 24 volts, I guess I would have to do some re-wiring on the 360. You are right about the high buck price tag.
I think that the Autoflo humidistat that Dan mentioned will do everything that I need without all the bells and whistles. Thanks guys for the advice. -Ed0
- 62 Biomass
