hidden leak under slab
jim murtaugh
Member Posts: 72
I service a 12 unit building w/hot weter heat and suspect a leak in one of the lower apts.I tried installing ball valves for isolation and still looking.any one know any good leak finding companies in the chicago area.
how about trying
American Leak Detection
7982 Illinois Rt. 2 South, Dixon, IL 61021
815-652-1000 FAX: 815-652-1000
americanleak@grics.net
gwgillplumbingandheating.com
leak
Thanks I will give them a call0 -
I just read Dan's book Hydronic Radiant Heating ( great read BTW ). He tells a funny story about a guy trying to find a leak in slab only to have the lady HO show him how w/ a mop.She ran the mop over the floor and watches as the pipes showed up as lines and the leak showed up as a circle (fascinating ). Another thing he talked about is using a stethoscope? That might help.0 -
Several options...
...one Wallie mentioned Leakbusters as an excellent outfit. They'll allegedly find just about anything.
The water-on-the-floor means of finding pipes works also, as long as they're good and hot. In carpeted areas, cats apparently are excellent indicators for localized hot spots. If you want to do this the new-fashioned way, borrow or rent a thermal camera. The thermal bloom should show up pretty quickly.0 -
thermal camera
First off I just happened on this web sight a couple of weeks ago now I find myself visiting and learning almost every day after 15+ years in the trade. I even took care of a h.o. who had some problems w/ his boiler although he did not accept my proposal to correct all of his issues.will this thermal camera work in carpeted areas?0 -
It should work...
...as long as the sensitivity of the camera is high enough. For example, I doubt that using infrared-film in a regular film camera would do the trick.
On the other hand, Wallies like hot rod and others have shown very fine temperature gradations while investigating various insulation schemes for staple-up pipe installs.
I'd crank the temperature of the supply water as high as is safe to get the pipes to really stand out from the background "clutter". The greater the ΔT between the pipes and the floor surfaces around them, the more they should stand out, regardless of how insulative the carpeting may be.0 -
yes they would, but
Jim,
Those cameras are very cool and very expensive. One company will lease them for $800 per week. They sell for anywhere between $7000 and $30000, so they are not is most people's budgets.
I'm pretty sure Hot Rod doesn't own the camera that he used for those great pictures.
jerry
Jim
Ive had real good exprerience using a hand held infra red scope . Fairly inexpensive and trustworthy. Reytec or Raytec makes a good one.0 -
raytec
I have a pretty good raytec I will give it a shot
thanks0
