electric water boiler help
[Deleted User]
when i turn on the main water suppy to boiler it keeps putting water into it and it gets to high and the pressure release valve opens and i have to close the main water supply coming into it. it didnt always do this. please help.
help
you need a pro call someone0 -
re: electric hot water boiler
do you know of anything that might be causing this problem. i had to replace some of the main line when i turned the water on again this is what happend.0 -
waterleak
whats the pressure gauge read? could be a bad relief valve,bad reducing valve or a bad expansion tank0
- 85.7K THE MAIN WALL
- 49 Biomass
- 72 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 372 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 39 Industry Classes
- 15 Recall Announcements
