Expansion Tanks and air vents
Craig Drabenstadt
Member Posts: 7
If you have a conventional bladderless air tank is it wise not to have any automatic air vents on the system. I would think that you want the air in the system to return to the tank.
You can have them as long as you keep them closed. The air WILL find its way from the tank to any autovents over time.0
