Expansion Tanks and air vents
If you have a conventional bladderless air tank is it wise not to have any automatic air vents on the system. I would think that you want the air in the system to return to the tank.
  • Uni R
    Uni R Member Posts: 663
    You can have them as long as you keep them closed. The air WILL find its way from the tank to any autovents over time.
