primary/secondary or heat exchanger
pat_3
pat_3 Member Posts: 89
when doing a small radiant system that will be tied into an existing hot water {high temp} heating system,do most radiant contractors repipe the boiler primary/secondary or use some sort of heat exchanger to protect the boiler from low temp return water from radiant side of system?
