Can I use this radiator ?
Dan m_2
Member Posts: 15
I need a radiator for a room in my house. My house has a hot water system with a fairly new boiler. I have found a old steam radiator from a one pipe system at a local heating contractor and brought it home.The contractor does mostly forced air and stated that I could convert it for my hot water heat system. The steam radiator has a plug on one end that would allow me too install a second pipe. but what about flow ? my other radiators allow for water flow at the top of the radiator as well as the bottem while this radiator appears to be set up for flow at the bottom only (Tops are connected but dont appear to have water passage). Can it work or shouild Pass it up ?
Thanks
Dan
Thanks
Dan
sounds like
a classic steam only radiator..you need the upper passage for water..gwgillplumbingandheating.com
If you can
take a picture and post it here. We should be able to identify it.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0
- 87K THE MAIN WALL
- 115 Chimneys & Flues
- 106 Geothermal
- 982 Plumbing
- 388 Solar
