Out with the old, in with the new. Pics included.
Ted_9
Member Posts: 1,718
This is an install for my tenants apartment.
Existing system. Oil fired boiler. Mono flo 1" loop with cast iron rads circa 1950s? Separate gas fired water heater.
Modern system: We kept the mono flo system. I want to make everything vents to the outside so I went with a Munchkin T80 with Vision One for efficiency and max comfort. I got the indirect Triangle tube Phase 3 scratch n' dent. Used Grundfos circs and Taco Vortech air eliminator(which I like tremendously). I left an extra zone for the little radiant that I will add soon. Its to heat 2 tough areas. Just putting up some aluminum panels and pex with insulation. And just using a 3-way set off the high temp heating curve(love condensing boilers).
I had to get this running by move-in which was last night. So I have some wires and tubing to clean up.
PATRIOT HEATING & COOLING, INC.
Lucky tenants!
We love those T-80's!!!
Glad Chuck got you going!
Mark H
nice Job
I get a kick out of that little unit. I have only serviced them not installed. The unit's we have are installed on tables not mounted to the wall...I get a kick out of seeing it like that. How is it to service it that way? Again nice job!!0 -
Yep
What Mr Hunt sez..............very lucky tenants.Nice looking install Ted.Plans of a TRV set up down the road?A busy day you had.
cheese0
- 167 Indoor-Air Quality
