Furnace tempeture
JIMBO_2
JIMBO_2 Member Posts: 127
Could anyone give me a ball-park figure as to the maximum temp inside an oil-fired furnace. It's an OLD Thatcher octapus. Thanks . . . .
  • Bluenose_21
    Bluenose_21 Member Posts: 14
    inside?
    What do you mean inside? Are you talking inside the plenum? If so I would guessimate somewhere between 150-200, after a few minutes of running(you should have a high limit set at 225-250).
  • Boston Boiler
    Boston Boiler Member Posts: 70
    Personally, I would set the high limit at 180*.
    I'd say fan on at 130*, off at 110* but you called it an octapus so I'm figuring it's gravity.
    BB
