Outdoor reset for steam
Dave_23
Dave_23 Member Posts: 190
Is it possible, or theoretically impossible, to setup an outdoor reset system on a steam heat system?
  • JR_3
    JR_3 Member Posts: 4
    RE: Steam outdoor reset
    Please see Tekmar's #269 Steam Control. If you go to their website www.tekmarcontrols.com you can pull up the data brochuere on it. Hope that helps
  • hydronicsmike
    hydronicsmike Member Posts: 855
    Instead of...
    ...reducing the steam temperature, the amount of time steam is established in a system is varied based on outdoor temp.
    Mike
  • Uni R
    Uni R Member Posts: 663
    A fool's theory... (not serious)
    If you could attach enough blower doors, you could lower the atmospheric pressure which in turn would lower the boiling point as a method of setback for less than design days. The house would be extremely noisy, the electrical bills would jump and you would be sucking everything down your flu. On the plus side, your hemocrit levels should rise which would help you in any endurance sports... if the CO doesn't kill you first.
