Limit Tstat needed
Ken_INNC
Ken_INNC Member Posts: 1
I need a Tstat that I can lock at a max temp due to some not to responsible people living in my house. It seems that when she goes into a room she is always cold and maxes out the thermostat. Please note that they never get turned down when she leaves the room. As stupid as this is I can’t be the first to hit on this problem.
What I am after is a low voltage preferably digital thermostat that I can lock at 70 (max) internally. The “lock box” cover is not an option due to cosmetic reasons.
Keep in mind this is for a hydronic radiant floor system with 10 zones so need 10 of them and cost does become an issue. www.tekmarcontrols.com
  • Mitch_4
    Mitch_4 Member Posts: 955
    can you
    use dummy stats? if its radiant and you are using slab sensor for temp control, hide it somewher inthe zone, but out of site. I have used this in office buildings.
  • hydronicsmike
    hydronicsmike Member Posts: 855
    pssst........
    do you have three wires at the thermostat location?? If so, call me at 250-545-7749, ext. 214. I may have what you need.
  • Todd_9
    Todd_9 Member Posts: 88
    accustat
    Is a device we have used before. It is a fixed setpoint stat. Tenents can always figure a way to get more heat.
  • Weezbo
    Weezbo Member Posts: 6,231
    We arent suppose to tell you these things:)
    they are trade secrets:)
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    I like the Accustats too.
    We had just the opposite problem and these were the answer. Seemed the church organ would go out of tune if the temp. dropped BELOW 65°, and the folks leaving after choir practice would bottom out the thermostat. I installed a dual bulb Accustat with the low bulb at 65° and the high bulb at 70°. The switch on the bottom is 3 position On-Off-High. Not too horrible to look at and pretty darn accurate. good luck. Chris
  • oil-2-4-6-gas
    oil-2-4-6-gas Member Posts: 641
    tenants
    we used to have a contract with a housing project --installed room sensors etc.. we were suppossed to be trimming their fuel usage ..after a few months and the numbers guys started checking fuel usage compared to earlier years we were using more fuel --decided to go through some key apartments and found things like bags of ice hung from the sensors,in 1 place they had a fan w/an ice bucket behind it --all fooling the sensors as well as maintenance guys tampering with the controls -you can get the military d.o.d. spec thermostat or the limit stat that goes to 72--but these are all easily manipulated -especially without the locking cover ---------good luck --it might be time to have a talk with the tenant -
