3\" 3 way mixing valve?
jalcoplumb_4
Member Posts: 3
Any one know who would make one? 3" four bolt flange. Will be operated by a tekmar 632 control.
3\" 3-way valves
Try contacting Danfoss, they carry the ESBE 3-way valves up to 6^.0 -
Honeywell V5013...
You also will need an actuator and/or linkage. Go to http://www.hbctechlit.honeywell.com, and key in V5013. Available from commercial Honeywell distributors.0 -
3 way valve
There are many; Siemens (Powers), Johnson, Honeywell, Invensis,to name a few. There are many imported off brands available too. You can get them with any type of actuator, or none at all.
The following web sites may help:
http://www.cappusa.com/
http://www.us.sbt.siemens.com/home.asp
http://www.sbt.siemens.com/hvp/components/products/valves/default.asp
http://www.paxtoncorp.com/
http://www.invensysibs.com/catalog.shtmlhttp://www.statesupply.com/
http://www.johnsoncontrols.com/
Thank you all.
For your help.0 -
Cv
Be sure to get the correct Cv rating for the application if this is for mixing. Also any number of motor speed options to consider.
Tim D.
