ABC OIL BURNER PARTS NEEDED
SOME ONE CHANGED THE SPINNER THAT ATACHES TO THE NOZZEL ADAPTOR, TO A CARLIN STYLE FLAME RETENTION RING. THIS GUN WONT SET UP! LOOKING FOR AIR HANDLEING PARTS FOR ABC BURNNER THAT WENT IN TO A P535 WIEL MCLAIN. THE GUN IS MARKED WIEL MCLAIN BUT IS ACTUALY AN ABC OEM FOR WIEL MCLAIN. ANY GOOD IDEAS FOR A BECKET TRANSPLANT WITH THAT ABC MOUTING ASMEMBLEY
  • richpoirier
    richpoirier Member Posts: 10
    45CU ABC
    GUN WAS IN A WIEL MCLAIN, NEED AIR HANDLEING PARTS FOR IT
  • Firedragon_4
    Firedragon_4 Member Posts: 1,434
    These guys were the
    last caretakers of ABC/Sunray and Oertli parts:
    Enerjet Corp.
    45 Drexel Dr.
    Bay Shore, NY 11706
    516-273-3939; fax: 516-273-3088
    They may be gone since they were charged by the FTC for mislabeling equipment three years ago and lost. If they're gone, so is the largest cache of these parts, FACT!
  • richpoirier
    STILL LOOKING
    LOOKING FOR PARTS FOR 45CU-1-ABC , NEED AIR HANDLEING PARTS FOR GUN
  • techheat_2
    techheat_2 Member Posts: 117
    Please stop the caps! You need a new burner and if you have to ask how you install it,You need a professional.This is not a hobby and is potentially dangerous to life and property!
  • richpoirier
    What do you have against caps! I wish I did know it all but some times i have to depend on great enformation from other profesionals. I dont think a becket universal flange will work on this abc bolt pattern, im simply looking for ideas from other professionals as to what the options might be, or who has a burner flange large enough to take on abc bolt pattern. i dont want to do a pedestal install ,
  • Patchogue Phil_27
    Patchogue Phil_27 Member Posts: 15
    631 area code now
    Bay Shore is now 631 area code, not 516. But, if'n they are out of business it is a moot point.
  • B. Tice
    B. Tice Member Posts: 206
    ABC
    Take a Beckett flange and cut off the outer parts of the slots, and use some fender washers.I've done about 50 of these.
  • Bill Nye_2
    Bill Nye_2 Member Posts: 538
    CAPS
    Are hard to read. It is Considered YELLING in most places. I had a pretty good stash of old burners and some ABC sunray stuff. I filled a dumpster with them last April.
    Do you have any problem with Beckett, Carlin or Riello?
  • rich poirier
    rich poirier Member Posts: 1
    thanks to those who gave me some good ideas
    im going to go with the becket flange and some large washers to mount the gun, to steam head and the others who answered me with some good sugestions, and dope on the **** gun, you are true professionals who dont mind sharing a little of your experiance. thank you!
    i thought the dumpster idea took the cake with adding some levity to a losey abc burner problem, keep the jokes comming!
    Steamhead Member Posts: 18,208
    Rich, you might want to hang onto that ABC
    I'm sure it still has many usable parts which could get someone else out of a jam sometime.
    Consulting
  • parts for ABC/Sunray
    Brentwood Plumbing & Heating Supply
    1059 Suffolk Avenue
    Brentwood ,NY, 11717
    631-273-5930
