ABC OIL BURNER PARTS NEEDED
richpoirier
Member Posts: 10
SOME ONE CHANGED THE SPINNER THAT ATACHES TO THE NOZZEL ADAPTOR, TO A CARLIN STYLE FLAME RETENTION RING. THIS GUN WONT SET UP! LOOKING FOR AIR HANDLEING PARTS FOR ABC BURNNER THAT WENT IN TO A P535 WIEL MCLAIN. THE GUN IS MARKED WIEL MCLAIN BUT IS ACTUALY AN ABC OEM FOR WIEL MCLAIN. ANY GOOD IDEAS FOR A BECKET TRANSPLANT WITH THAT ABC MOUTING ASMEMBLEY
45CU ABC
GUN WAS IN A WIEL MCLAIN, NEED AIR HANDLEING PARTS FOR IT0 -
These guys were the
last caretakers of ABC/Sunray and Oertli parts:
Enerjet Corp.
45 Drexel Dr.
Bay Shore, NY 11706
516-273-3939; fax: 516-273-3088
They may be gone since they were charged by the FTC for mislabeling equipment three years ago and lost. If they're gone, so is the largest cache of these parts, FACT!0 -
STILL LOOKING
LOOKING FOR PARTS FOR 45CU-1-ABC , NEED AIR HANDLEING PARTS FOR GUN0 -
Please stop the caps! You need a new burner and if you have to ask how you install it,You need a professional.This is not a hobby and is potentially dangerous to life and property!
What do you have against caps! I wish I did know it all but some times i have to depend on great enformation from other profesionals. I dont think a becket universal flange will work on this abc bolt pattern, im simply looking for ideas from other professionals as to what the options might be, or who has a burner flange large enough to take on abc bolt pattern. i dont want to do a pedestal install ,0 -
631 area code now
Bay Shore is now 631 area code, not 516. But, if'n they are out of business it is a moot point.
ABC
Take a Beckett flange and cut off the outer parts of the slots, and use some fender washers.I've done about 50 of these.0 -
CAPS
Are hard to read. It is Considered YELLING in most places. I had a pretty good stash of old burners and some ABC sunray stuff. I filled a dumpster with them last April.
Do you have any problem with Beckett, Carlin or Riello?0 -
thanks to those who gave me some good ideas
im going to go with the becket flange and some large washers to mount the gun, to steam head and the others who answered me with some good sugestions, and dope on the **** gun, you are true professionals who dont mind sharing a little of your experiance. thank you!
i thought the dumpster idea took the cake with adding some levity to a losey abc burner problem, keep the jokes comming!0 -
Rich, you might want to hang onto that ABC
I'm sure it still has many usable parts which could get someone else out of a jam sometime.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0 -
parts for ABC/Sunray
Brentwood Plumbing & Heating Supply
1059 Suffolk Avenue
Brentwood ,NY, 11717
631-273-5930There was an error rendering this rich post.
