latest install
Dave Palmer_3
Member Posts: 388
installed this Biasi B10-5 with a W/M plus 40,replaced a 6 section arco-liner and 3 60 gallon electric water-heaters.pressed as much as I could.Lucky I didn't have to change or build manifolds.Pretty smooth,Dave
Nice
Nice job on the piping!! What do you think of the Biasi? I have to install one in a couple week's and it will be the first for me. Does the Biasi clean from the front? Is it a quiet unit? Again excellent job on the install!!0 -
noise
Reminds me of a Pensotti. How finicky was it to set up the burner? how about noise? we got lots of noise complaints with the Pensotti , LOTS of Riello Roar.0 -
WHAT NOISE????????
YES MAME IT'S MUCH QUIETER THAN THE LAST ONE WE DID...nice little boiler,did one Friday with a Reillo,same sounds as a Carlin. Maybe outside air kit would work.I've got a Veissman with there chassis burner in my own home thats just as loud.I like them w/ the Carlin just because I'm used to them and you don't need a separate relay just to pull in the burner.Seems like breech noise if anything...wonder if you ran insulated flue pipe?The last two 4 sections I did were 86% eff. I wonder why they don't insulate all the way around the block too.Dave0 -
sets up
easy,can't use a Carlin in the 3 section though.If you use a Carlin it should be a welded flange just so you don't have air leaks around the burner.Would love to try a HEAT-WISE burner. a photo of another nearly completed 4section ,Dave0 -
Great looking install...
...neat, straight, and easy to service. What else can one ask for?0 -
Propress....
Dave,
Nice work!
JR
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"I am the walking Deadman
Hydronics Designer
Hydronics is the most comfortable and energy efficient HVAC system.0 -
thanks guys
- 167 Indoor-Air Quality
