need manual on old abc burner, help!!!!
help!! need book on old abc burner. its in a p535 wiel mclain. any tricks to set this pig up with out specs?
    Steamhead Member Posts: 18,205
    Try \"Just for Teks\"
    which is a part of Oil Tech Talk. Go to
    www.oiltechtalk.com
    then click on Just for Teks. At the bottom of the JFT main page you will find a link to "Some Older Oil Burners" which includes lots of ABC-Sunray units. You can print these out if you wish.
    You might also get in touch with Weil-McLain at
    www.weil-mclain.com
    If that's the original burner, which it probably is, they should have the setup info.
    I also have an old ABC-Sunray, and can get 13% CO2 out of it with zero smoke. Of course I open it up to 12% for headroom. As long as the air- and flame-handling parts of these burners are in good shape, you can get good efficiency from them.
    Consulting
