need manual on old abc burner, help!!!!
richpoirier
Member Posts: 10
help!! need book on old abc burner. its in a p535 wiel mclain. any tricks to set this pig up with out specs?
Try \"Just for Teks\"
which is a part of Oil Tech Talk. Go to
www.oiltechtalk.com
then click on Just for Teks. At the bottom of the JFT main page you will find a link to "Some Older Oil Burners" which includes lots of ABC-Sunray units. You can print these out if you wish.
You might also get in touch with Weil-McLain at
www.weil-mclain.com
If that's the original burner, which it probably is, they should have the setup info.
I also have an old ABC-Sunray, and can get 13% CO2 out of it with zero smoke. Of course I open it up to 12% for headroom. As long as the air- and flame-handling parts of these burners are in good shape, you can get good efficiency from them.
To Learn More About This Professional, Click Here to Visit Their Ad in "Find A Professional"All Steamed Up, Inc.
Consulting0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
