Cast Iron Radiator Disassembly
Cold N Mke
Member Posts: 1
I have a crack in a raised seam of a casr iron radiator. I tried JB Weld but the position is bad, and found another crack on an inner section that I can't reach. Any tips on disassembly?
Thanks
Thanks
Look here
There is an article in the "Hot Tech Tips" section of this site that deals with this subject.
I have done this a couple of times with success.
http://www.heatinghelp.com/newsletter.cfm?Id=20
Good luck
JimThere was an error rendering this rich post.
- 85.7K THE MAIN WALL
- 49 Biomass
- 71 Chimneys & Flues
- 92 Geothermal
- 149 Indoor-Air Quality
- 3.2K Oil Heating
- 59 Pipe Deterioration
- 847 Plumbing
- 5.8K Radiant Heating
- 371 Solar
- 14.5K Strictly Steam
- 50 Water Quality
- 38 Industry Classes
- 15 Recall Announcements
