Boiler Manufs: Crown vs. Weill-McLain
Hello everyone. I am presently receiving bids to replace the gas-fired hot water boiler in my house. I've gotten one bid for $3,9000 for a Crown Aruba boiler, and one for $4,500 for a Weill-McClain CGs boiler. I trust both contractors more or less equally. Is there a difference in the quality of the two products that would justify the extra $600, or should I just go with the Crown?
Thanks,
Brian
  • John Mills_3
    John Mills_3 Member Posts: 221
    Read the fine print
    and see if both contractors are doing identical work, replacing identical components, chimney liner if needed, etc. Both boilers are good and should be similarly priced so your big diff in bids is either just the pricing of the dealer or one doing more or less than the other.
  • clammy
    clammy Member Posts: 3,242
    what about the others
    Have you looked into any other boiler besides mclean and crown how about buderus ,htp boiler the munchkin may be get something that over time could be up graded with controls and give you a much better bang for your bucks and be more effecent from the get go peace clammy
    R.A. Calmbacher L.L.C. HVAC
    NJ Master HVAC Lic.
    Mahwah, NJ
