1935 steam pipe leaks - hairline crack
charlie_8
charlie_8 Member Posts: 1
is there a way to seal the steam hairline crack without replacing the pipes and disconnecting the pipes and radiator and then reconnecting all of the above?????
  • joe_31
    joe_31 Member Posts: 24
    steam pipe cracked
    i once used steel wool pulled thin soaked in salty water to corrode close a crack in cast ecentric fitting under the direction of an old timer worked after chiseling it into the crack wraping it with oakum
  • bob young
    bob young Member Posts: 2,177
    try black & white or epoxy. you could get lucky
  • Boiler Guy
    Boiler Guy Member Posts: 585
    Wow
    Now that's a serious amount of work. I've used lead wool tapped into a sand hole on cast iron
