1935 steam pipe leaks - hairline crack
charlie_8
Member Posts: 1
is there a way to seal the steam hairline crack without replacing the pipes and disconnecting the pipes and radiator and then reconnecting all of the above?????
steam pipe cracked
i once used steel wool pulled thin soaked in salty water to corrode close a crack in cast ecentric fitting under the direction of an old timer worked after chiseling it into the crack wraping it with oakum0 -
try black & white or epoxy. you could get lucky0 -
Wow
Now that's a serious amount of work. I've used lead wool tapped into a sand hole on cast iron0
- 86.7K THE MAIN WALL
- 56 Biomass
- 104 Chimneys & Flues
- 5.6K Gas Heating
- 103 Geothermal
- 159 Indoor-Air Quality
- 69 Pipe Deterioration
- 942 Plumbing
- 6.2K Radiant Heating
- 385 Solar
- 15.3K Strictly Steam
- 43 Industry Classes
