Gravity Overheat Loop route
C.Hall
C.Hall Member Posts: 2
The Tarm wood boiler I am piping requires a gravity flow overheat loop to dump heat in case of power outage with fire still lit. At their schematics page http://woodboilers.com/piping-layouts.asp this overheat loop can be seen returning up-stream of a circulator (C-3). Shouldn't this loop be returned downstream from this circulator, if the gravity flow is to be unobstructed?
Could this circulator be installed in an alternate location in the primary loop?
  • Robert O'Connor_6
    Robert O'Connor_6 Member Posts: 299
    The
    outlined piping is effective for a "dump" zone.I would dump to as a many zones as possible.
    Regards
    Robert
    ME
