Need recomendations for new steam boiler
We have to replace an old Weil-Mclain oil fired steam boiler, with a tankless coil, for a 3 story, 6 family, semi-attached brick building.
Seriously considering converting to gas, since we will also be installing gas dryers for a new laundry room in basement.
Old burner is firing at 3.2 gal/hr. Existing radiation of 1050 sq. ft.
I WOULD GREATLY APPRECIATE YOUR ADVICE/OPINION:
Which Boiler and Burner manufacturers should I consider?
Is there a better way to provide domestic hot water?(especially since we will also have 2 washing machines)
Would you convert to gas?
Many Thanks!
