thred sealent
RoosterBoy
Member Posts: 459
hi dose anyone know of a good thred sealent that will harden like a rock and will be a b***ch to unscrew off
or never get off unless cuting the pipe
this is for 2" black iron pipe for my oil tank fill cap and vent cap
thanks
thanks
Two part
epoxy. I've seen it used to join copper fittings by "irrigation specialists" and was amazed how well it worked.
Loctite...
There's lots of choices - #2760 is a high strength threadlocker.0 -
THREAD SEALANT
THE PRODUCT CALLED EXPANDO0 -
umm why?
You may want to use a regular pipe dope rated for oil. I can understand you don't want it to leak but creating something that can never be taken apart or take's 3 men and a boy to undo could create nightmare's down the road. What will happen if you need to move the tank? I have put in plenty of oil tank's and never had issue's with leak's...JMHO..:)0 -
I don't believe
you could ever get a product to lock that tight! I've used Expando, but still, a large enough wrench will unscrew it.
If it has to be that tight weld it!
hot rod
Use any pipe dope
Just be sure to coat the threads with roofing cement!
More UST's have been condemmed due to pipe leaks rather than tank leaks - than any other "mistake" in that field of endeavor can muster!
EXPANDO
EXPANDO was commonly used in older steam lines headers etc.. you will destroy and deform the pipe before it will come apart but all you need is rectorseal #5 or any oil rated sealant and learn how to pipe when you think its as tight as you can get it --go 1/4 turn more0 -
You got that right. Never seen an expando joint come apart in reusable condition.0 -
Pipe dope
a few years back I used a pipe dope called "Grrrip", I think it was a Hercules product. Stuff looked like coal tar, real thick, if it was below 50 degrees you couldn't get the brush out of the can! Set up real hard and was a B***h to get apart!
Very similar to "Permatex form-a-gasket".
Don't know if is still available.
JimThere was an error rendering this rich post.
when all else fails----PERMATEX0 -
Hercules Makes Grrrrrrrip.
Loctite #568 is basically the same stuff. Don;t get it on your hands. If you do, for the next 3 days, ev eryone will know it!0 -
Two part epoxy ....And my personal favorites Grip and Permatex
2 part is the stuff to "Mop"on welds or threads underground however i like using grip over the tank welds and over the threads under ground on the black iron fill and supply pipes i then cover the pipe to 6" aboveground level with wonder tape,then re mop the seal near tank and threads ,and near the pick point welds...i am a lu fanatic
then again havent had alot of call backs .... 0 -
superdop!
Used a product called superdope on a sprinkler system, good for fuel too. "hardens to pipe burst strength" Put it on with 14" wrench, remove with 36"
You do not want to screw up with this stuff. (from experience)0 -
Sorry
When you think all else will fail EXPANDO wont. The other posts are right. There IS no other.0 -
thread seal
product called leak lock , sells in small bottle ,blue in color .0
- 167 Indoor-Air Quality
