Thermostst alarm
MIKE6
MIKE6 Member Posts: 102
Looking for an alarm like a light to go on in a window for a summer house when the temp drops because of a no heat situation.Of course a neighbor would see it and call me.Local supply houses don't have any.Any ideas?
Mike
  • MIKE6
    Thermostst alarm
    Mike
  • wayne_11
    wayne_11 Member Posts: 14
    Honeywell Winter Watchman.
  • Kritz_3
    Kritz_3 Member Posts: 85
    Freeze Stat.
    Hi Mike,
    That is not to hard to make up, The item is called a freeze stat
    (low limit cut out). They have contacts for N.O. and N.C. wire it
    up to a indicator light on the N.O. conacts. They have a temperature set point adjustment down to 35'F. Look for the item
    at Grainger,Johnstone,any HVAC supplier should have it.
    Steve
  • Kritz_3
    Freeze Stat.
    Hi Mike,
    at Grainger,Johnstone,any HVAC supplier should have it. Good luck,
    Steve
