Thermostst alarm
MIKE6
Member Posts: 102
Looking for an alarm like a light to go on in a window for a summer house when the temp drops because of a no heat situation.Of course a neighbor would see it and call me.Local supply houses don't have any.Any ideas?
Mike
Mike
Thermostst alarm
Mike0 -
Honeywell Winter Watchman.0 -
Freeze Stat.
Hi Mike,
That is not to hard to make up, The item is called a freeze stat
(low limit cut out). They have contacts for N.O. and N.C. wire it
up to a indicator light on the N.O. conacts. They have a temperature set point adjustment down to 35'F. Look for the item
at Grainger,Johnstone,any HVAC supplier should have it.
Steve0 -
Freeze Stat.
Hi Mike,
at Grainger,Johnstone,any HVAC supplier should have it. Good luck,
Steve0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
