direct vent oil fired boiler
pat_3
Member Posts: 89
how come there seems to be a very small selection of direct vent oil fired boilers?i have no experience with oil fired boilers,but was recently asked to install two in a customers home ,while pricing out the equipment i realized there were n't many options.i am assuming there is a good reason . any responses are greatly appreiciated
It is a relatively...
new set up...although there are more now than there were a few years ago. A chimney is still the better way to go....kpc
i am also looking at the Best way to install LE
i am thinking a riello bf maybe...0 -
Burnham LE
doesn't offer a Riello option, Beckett AF only. While not all models are offered in a DV model, most of the small high efficeny models are: Buderus G115, Crown Freeport, Laars DMAX, Columbia LV, and many others. All makers offer a DV oil fired balanced flue model. As long as you have very good window/door clearances and no issues with high wind pressure areas like inside corners of a building, the only issue might be staining of some sidewalls.0 -
Mainly because until
we get low sulfur fuel the problems and service costs outweigh the fuel savings, JMO!0 -
clearance
how much clearance is needed from windows or doors?There was an error rendering this rich post.
Most install instructions
say 4 ft from any door, window, inside corner or other air intake and none directly above the vent. One to 2 feet from the soffit. Also 7ft above if directly under a walkway and 1 ft to 18" above the snow line.0
- 167 Indoor-Air Quality
