Flow check or Spring check
Kritz_3
Kritz_3 Member Posts: 85
Just a quickie, On returns heading towards a low loss header,
what would be the preferred check valve a sping or flow type check
valve. I will be installing flow check equiped pumps . Thanks in
advance.
  • J.C.A._3
    J.C.A._3 Member Posts: 2,980
    pump checks
    Should be more than enough. Don't sweat it, as Dan says, "think like water". Chris
  • Kritz_3
    check valves
    Viessmann specs out checks on the return legs , Just wondering
    if a spring checks Cv will pose a problem?
