Flow check or Spring check
Kritz_3
Member Posts: 85
Just a quickie, On returns heading towards a low loss header,
what would be the preferred check valve a sping or flow type check
valve. I will be installing flow check equiped pumps . Thanks in
advance.
advance.
pump checks
Should be more than enough. Don't sweat it, as Dan says, "think like water". Chris0 -
check valves
Viessmann specs out checks on the return legs , Just wondering
if a spring checks Cv will pose a problem?0
- 87.4K THE MAIN WALL
- 167 Indoor-Air Quality
