circuit setters
K.Black
K.Black Member Posts: 26
Could anyone tell me what they use(brand) and a good test kit for setting them. I currently use tour anderson valves under the victaulic brand name. I want to start ballancing my own projects valves,its costly to bring someone in for 10-15 valves not to mention availibility. THANKS
  • Bud_14
    Bud_14 Member Posts: 200
    Bell & Gossett
    http://www.bellgossett.com
    Try these guys out at their technical articles, search for circuit setters. Don't know if it will help you, but I assure you, you will probably leave their website a smarter tech.
    Bud
    www.thesheetmetalshop.com
  • heaterdude
    heaterdude Member Posts: 4
    Nexus
    pre-set flow regulators. Order by gpm, install, check for min 2 psi drop and walk away.
