circuit setters
K.Black
Member Posts: 26
Could anyone tell me what they use(brand) and a good test kit for setting them. I currently use tour anderson valves under the victaulic brand name. I want to start ballancing my own projects valves,its costly to bring someone in for 10-15 valves not to mention availibility. THANKS
Bell & Gossett
http://www.bellgossett.com
Try these guys out at their technical articles, search for circuit setters. Don't know if it will help you, but I assure you, you will probably leave their website a smarter tech.
Bud
www.thesheetmetalshop.com0 -
Nexus
pre-set flow regulators. Order by gpm, install, check for min 2 psi drop and walk away.0
- 86.6K THE MAIN WALL
- 54 Biomass
- 98 Chimneys & Flues
- 5.5K Gas Heating
- 101 Geothermal
- 157 Indoor-Air Quality
- 3.5K Oil Heating
- 64 Pipe Deterioration
- 931 Plumbing
- 6.2K Radiant Heating
- 384 Solar
- 15.2K Strictly Steam
- 42 Industry Classes
- 48 Job Opportunities
