pipe water volume?
larry_9
larry_9 Member Posts: 33
Are you talking gpm of water or volume?
  • ernie_3
    ernie_3 Member Posts: 191
    pipe water volume?
    I'm looking for a good web site for water volume. What pipes carry, both copper and steel, from 1/2" to 3". Thanks in advance.
  • ernie_3
    gals. per foot
  • pete_14
    pete_14 Member Posts: 9
    gpm in pipe
    formula=Diameter squared in inches multiplied by .0408 multiplied by length in feet = gallons
  • larry_9
    Gpm for pipe
    Ernie:
    Pete is right for the volume of pipe. However, if you are talking about gpm then oyu need to take into consideration velocity, other wise you could end up with noise problems. B&G (Bell and Gossett) makes a system sizer for those who design and those who balance systems. It is called a System syzer calculator and it goes up to 3" copper tubing and up to 12" iron pipe I hope this helps.
