Heat Exchangers
S Davis
Member Posts: 491
What brand of heat exchangers do you guy's use for swimming pool heating?
S Davis
Apex Radiant Heating
S Davis
The problem with heat exchangers around pools is that all too often, the combustion air is drawn from around the pool area. Chlorine will eventually eat a heat exchanger alive (kinda makes you wonder about us!) If you have a system totally isolated from the pool (taking combustion air from elsewhere), you should get more life out of your heat exchanger.0 -
Heat Exchangers
I guess I should have been more clear, I mean for heating swimming pool water from a boiler.
S Davis
Apex Radiant Heating0 -
Well, the wall may prove me wrong, but I guess I'd feel safe with cast iron. You'd still have fits if the combustion air is drawn from around the pool.0 -
pool H.E.
if it is a salt water pool - you MUST use titanium. Otherwise a stainless will suffice.
I like the Seces-Pol Line (B-Series)
www.secespol.com
whatever you do - DO NOT use cast iron... or anything close to ferrous.
cheers!
EIN0 -
I think he is looking
for an indirect type of heat exchanger to run off a boiler in another location? I have used the Triangle Tube and Weil Mclain, possibly the same brand.
hot rod
flat plate
marine grade exchangers, have worked very well for us. marc.0 -
flat plate
- 167 Indoor-Air Quality
