Wood above subfloor infloor heating
Chuck_7
Chuck_7 Member Posts: 71
Have you had good experiences installing infloor radiant above a wood subfloor with wood furring and aluminum heat transfer plates (I'm trying to describe this as genericly as possible)?
How is the response. Will on/off control work OK?
(residential construction)
